gadget1961 5 Posted January 20, 2011 i have a problem , i get to the part of getting a wording and adding a symbol and when complete , i saved it , now i go back and open it and it looks great , but now when i want to cut it , it all arranged differently , what can i do to keep the word and symbol all in line where it is suppose to be thanks any help to set me straight Share this post Link to post Share on other sites
bayotle 26 Posted January 20, 2011 i have a problem , i get to the part of getting a wording and adding a symbol and when complete , i saved it , now i go back and open it and it looks great , but now when i want to cut it , it all arranged differently , what can i do to keep the word and symbol all in line where it is suppose to be thanks any help to set me straight I believe you need to weld it together, otherwise (assuming you use SB) it will rearrange it to save on vinyl.... That may help, may not, I'm still a noob myself! Share this post Link to post Share on other sites
Jay2703 704 Posted January 20, 2011 At the top of the cutter window there are two tabs. In the "Save Space" tab, make sure that nothing is checked. http://screencast.com/t/6vmChzBaJLl Jay Share this post Link to post Share on other sites
Rodger 527 Posted January 20, 2011 When I make a decal & don't "combine " it I can't use the align option . It will put everythinjg on top of each other . I select everything & drag it to the lower bottom corner to cut . If what Bayotle or Jay said does not fix it , explain what is happening more . Share this post Link to post Share on other sites
Jay2703 704 Posted January 20, 2011 When I make a decal & don't "combine " it I can't use the align option . It will put everythinjg on top of each other . I select everything & drag it to the lower bottom corner to cut . If what Bayotle or Jay said does not fix it , explain what is happening more . If I want to use align, I usually will group instead of combining. You can group different colors without changing them but if you combine everything changes to the same color. Share this post Link to post Share on other sites
gadget1961 5 Posted January 20, 2011 ok i figured it out their was a line near the bottom of when i clicked cutter,, and the wording i was putting in was half and half like between the line , 9 dont know where it came from ) , also unchecked a box (checked for 2 lines) and i brought the word under the line and everything came together , before it had 2 cuts and of the same color well their is always a learning process , i dont have a problem from my cliparts just when i make something from scratch thank you guys , i now have a bald spot from scratching my head and still have some hair left for another problem ;D haha Share this post Link to post Share on other sites
Rodger 527 Posted January 20, 2011 That is a new option for me . I'll have to try that , thanks Jay . I wonder what the new evolved SignBlazer software will be like whenever it finally comes out . It has been 2 years since I first read reports of an evolved software . I do believe it is being developed despite some thinking it is just false rumors . Share this post Link to post Share on other sites
