ea25id 0 Posted December 20, 2010 I have been cutting for about a month and my paper is starting to lift up in some cuts. Is this potentially because I have to replace the blade? Also, what are the different angles of different blades for? ALOHA! Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted December 20, 2010 if you are cutting paper it will dull faster - if you are cutting vinyl then I would back the blade out a little. as you use the blade the offset will change a little as the hone on the blade changes also. personally I changed to 60 degree cleancuts for everything Share this post Link to post Share on other sites
