Racer10 0 Posted January 3, 2008 Anyone help with why this file is just making a bunch of dots where the nodes are when I go to draw/cut? I have had problems with SB not cutting all the lines I see on the screen, but not quite like this... This newbie is still trying to figure out what I think should be the basics. Thanks! OOS.eps OOS.eps Share this post Link to post Share on other sites
Jay2703 704 Posted January 3, 2008 When you are in Cut Mode there are 4 different colors. If you select all of them (hold the Ctrl button down while selecting) everything should cut. If you just use text to create this there should only be one color. How did you make this? Share this post Link to post Share on other sites
Racer10 0 Posted January 3, 2008 I haven't had any luck converting graphic files into Vecotor files in SB yet, so this was just a black and white word art the I vectorized with Stanford's Vector Magic. Thanks!! Share this post Link to post Share on other sites
Jay2703 704 Posted January 4, 2008 Why don't you just use the text function in SignBlazer? You can do all kinds of things with it and then you don't need to vectorize it. Just cut it. Share this post Link to post Share on other sites
Jerry Bonham 1 Posted January 6, 2008 Hello, The problem with this EPS file is that it had a rectangle that was transparent around it. I deleted this rectangle by first splitting the objects (press T on the keyboard) and then deleting the rectangle. I agree this could have been typed up in SignBlazer in less time than it took to do the post. Jerry from SignBlazer OOS.SBD OOS.SBD Share this post Link to post Share on other sites
Racer10 0 Posted January 7, 2008 Thanks Jerry! I finally found the font files I was looking for so I won't have to do such in the future. Share this post Link to post Share on other sites
