nenemott 0 Posted October 16, 2010 I was asked to make a 4x5 sign, problem is I do not have a large format printer, here is the design he wants, can anyone help. I would have to make a 5x4 vinyl print and put it on a 5x4 pvc board. Both sides. It would have to be laminated, as it is going outside of business store. Any suggestions? here is the kind of sign he wants, the sign below, he wants the chicken sign on it. Share this post Link to post Share on other sites
neron15210 10 Posted October 16, 2010 I will be more then glad to do printing for you. PM me if you are interested Also for outdoor usage I would avoid expended PVC. Share this post Link to post Share on other sites
mopar691 281 Posted October 16, 2010 Why avoid expanded pvc for outdoor??? Thats what it is for Share this post Link to post Share on other sites
nenemott 0 Posted November 2, 2010 here is the 5x4, it still looks good,thanks Share this post Link to post Share on other sites
neron15210 10 Posted November 3, 2010 @mopar691 No, Expand PVC (N Glantz sells it in different colors) is not meant for outdoor use (maybe for very short time) due to tendencies to warp. Share this post Link to post Share on other sites
mopar691 281 Posted November 4, 2010 well then i quess the 200 signs i have on expanded pvc are bad, and all the 3D signs everyone makes are bad. PVC was designed for outdoor use. I have never heard of it warping or failing due to weather, ive had some out there for 4 years, it still looks like the day i put it up. But for you to say its not for outdoor use is plainly wrong. I will tell you if you have a 10' sheet and screw it tight to a wood wall in the four gorners in the cool morning and then come back in the afternoon the heat from the sun causes alot of expansion and will appear warped. That is true with almost any substrate if mounted on something ridgid with different expansion rates. This needs to be taken into consideration when mounting andhow to go about your mount. Mounted correctly this material wil lay flat and stay true for many, many years. Its use in three dimensial signing is extremely widespread for its durability and its ability to withstand all weather enviroments. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted November 4, 2010 If you read the specs on Expanded PVC you get a variety of opinions.....Based on my research, it would not be my 1st choice for a long term application..... Share this post Link to post Share on other sites
neron15210 10 Posted November 4, 2010 I was talking about "Expanded PVC" N Glantz sells in different colors. It's reasonably priced , but when I asked manager about using it for outdoor purposes, he said "Stay away from it" Enough said. I'm not trying to be mart ass , just sharing my knowledge with guys here. Share this post Link to post Share on other sites
nenemott 0 Posted November 4, 2010 I am mounting it on polycarbonate, as the original is still in good condition, I am taking off the vynil letters and replacing them with the vynil print. thanks for your feedback. Share this post Link to post Share on other sites
mopar691 281 Posted November 4, 2010 My first choice is ACP or Alimincorr. This is a cheap alternative as a 10mm sheet is 1/4 the cost of anything else. And i am talking about "Expanded PVC". Share this post Link to post Share on other sites
nenemott 0 Posted November 4, 2010 HERE IS A JPG OF SOMEONE WHO POSTED THIS A WHILE AGO Share this post Link to post Share on other sites
