Rich 0 Posted October 1, 2010 1. How can I thicken lines of an image? 2. How do I take an image and outline it so the insides will be hollow? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 1, 2010 ok, is it inkscape questions? Or Flexi questions? And what version of Flexi? Pro? Flexistarter? You Have Flexi questions in an inkscape thread. Share this post Link to post Share on other sites
rrc1962 0 Posted October 1, 2010 (1) Just increase the stroke weight. (2) Use the outline tool. Select the clear center option in design central. After creating the outline, right click and "Separate Outline". The outline and the item outlined are now two separate pieces. Delete the original leaving just the outline. This assumes you are talking about Flexi, not Inkscape. Share this post Link to post Share on other sites
Rich 0 Posted October 15, 2010 I mean Inkscape, too many things going on in my head. Share this post Link to post Share on other sites
jcart 11 Posted October 18, 2010 I'm not an expert but try this: 1. To make the lines thicker, click on the stroke/fill area at the lower left hand of the page. A box will come up and you can increase the stroke size. 2. To outline with an empty center area on a solid image, Copy the image, drag it off the original and drag the corner to make it smaller than the original. Change color and slide it back over the original and center. Go to path and punch through. That should do the trick. Hope this helps...Jon Share this post Link to post Share on other sites
