Stlouistech 2 Posted September 28, 2010 I have tried the envelope tool and I also tried fit text to curve and I cannot for the life of me get it to center and curve the text to this image like the one I have attached. I am confused...I can get it partly in there, but when I move it, it goes crazy and looks all messed up. Any help would be awesome! Share this post Link to post Share on other sites
JoeBlow 5 Posted September 28, 2010 http://youthgrouptshirts.com/ygt/coreldraw-x4-adding-text-above-and-below-a-circle/ Joe Share this post Link to post Share on other sites
Stlouistech 2 Posted September 28, 2010 http://youthgrouptshirts.com/ygt/coreldraw-x4-adding-text-above-and-below-a-circle/ Joe I understand how to do this, I have tried to do that with this image....It wants to place the text on top of the image, I want it exactly like the picture in the middle curved to the image. Share this post Link to post Share on other sites
JoeBlow 5 Posted September 28, 2010 If the text is correct and the only problem is that it's on the top and not the bottom, just grab the little red square and drag it around the edge of the circle to where you want it. Joe Share this post Link to post Share on other sites
edge 67 Posted September 29, 2010 I've found on occasion my computer acts like it's overwhelmed when attempting to do what you describe and end up with similar results as you. I would describe this as the ADD syndrome, as it appears to have too many distractions from the design's other elements. Perhaps if you duplicate the design, crop out the elements not essential to the fitting of text. Insure the text is center formatted prior to attempting this and not too large for the path. Once it's in it's desired shape, you would then break it away and move it to the complete design. Share this post Link to post Share on other sites
Stlouistech 2 Posted September 29, 2010 This might help you better understand what I am doing. Share this post Link to post Share on other sites
mailman 1 Posted October 1, 2010 Go to advancedartist.com, he has a tutorial on fitting text into a sports tail, I think it will do want you want. It shows how to manipulate nodes to fit. Also he has a free sports tail download thats pretty nice. Mark Share this post Link to post Share on other sites
Ribs 2 Posted May 9, 2011 I would probably create a circle the same size as what you're trying to fit to, line it up, and use that (opposed to trying to fit the text to the odd shape). Much less hassle this way. Then delete the circle when you're done. Share this post Link to post Share on other sites
