Debra Payne 0 Posted September 22, 2010 I want to cut a rhinestone template and the downforce is recommended at 250. Is that term the same as the pressure setting on the LP24? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 22, 2010 yes, you would need more force for cutting that than regular vinyl Share this post Link to post Share on other sites
Debra Payne 0 Posted September 22, 2010 according to the instructions, I have set the pressure as high as it will go and cut the speed down as low as it will go. When I tried to cut it this time, it didn't feed through the cutter right and made a big mess. It did cut the first line of the tile just fine but when it went to cut the holes, it wadded up the vinyl. Any suggestions?? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 22, 2010 sorry, I don't know what they are. do you have to cut all the way thru it? If so, do you have it on a carrier sheet? Share this post Link to post Share on other sites
Jay2703 704 Posted September 22, 2010 I would try a little more blade and less pressure. Share this post Link to post Share on other sites
Debra Payne 0 Posted September 22, 2010 how do I give it more blade? I am a newbie~ Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 22, 2010 make the blade just a little longer sticking out of the bottom of the blade holder. Share this post Link to post Share on other sites
Debra Payne 0 Posted September 22, 2010 another stupid question, How do I get the blade carrier out of the head? I took the big silver screw out and I thought it would swing open but it didn't and I don't want to force it. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 22, 2010 please take some time and read your user manual for your machine and get to know your machine. http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=42&nav=0 Share this post Link to post Share on other sites
lueman 19 Posted September 27, 2010 I had the same problem when I first got my machine just loosen the screw and VERY gently separate the holder arms just enough to pull out the holder. Please be gentile. Share this post Link to post Share on other sites
