Jwilkinson 0 Posted September 11, 2010 I've messed with my pressure and speed to no end and I keep getting the same issue. When I am cutting a square, the cutter cuts perfectly from left to right and up and down, but when it cuts right to left it seems as if the blade is stuttering and making the straight line jagged. Then when i take it off the machine I need to cut it by hand in those spots. It does this the entire width of the line. It seems like the blade isn't turning correctly in the holder and it is actually cutting with the blade in the opposite direction. At least that's my thought. Any ideas or thoughts? Like I said I've lowered my speed to the slowest and raised to the fastest, adjusted my pressure both up as far as I can without cutting through paper and as low as I can. Yet I still have this happen. If the width is only an inch or two it doesn't seem to be an issue, but anything larger and it leaves these jagged cuts. Thanks in advance!! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2010 have you looked into your blade holder to make sure there is no vinyl pieces , even a tiny piece can mess things up, put a drop of oil, 3-1 etc. or graphite on the blade. Make sure the carriage is firmly in it's track, make sure your cutting strip is firmly down all the way across, look at your blade REAL close and make sure it isn't damaged. try a different blade. Share this post Link to post Share on other sites
Jwilkinson 0 Posted September 11, 2010 I'll try the oil. I have used 2 separate blades thinking that may be the issue. I also have taken the blade out and checked the carrier to remove anything. Every thing else cuts flawlessly, just the right to left straight lines.. I'll have to get to the store for oil. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 11, 2010 just curious, what kind of vinyl are you cutting? also if you take the whole blade holder out of the carriage, and by hand holding the blade holder and running across some vinyl in all directions does it do the jagged lines? are you making (cuts/marks) into the vinyl backing when you are doing that? also make sure there are no gouges in your cutting strip. Share this post Link to post Share on other sites
TexLady7050 0 Posted June 20, 2011 Any luck? I am having the same issue. Share this post Link to post Share on other sites
mb20music 760 Posted June 24, 2011 Your cutting strip has gouges in it. You can sand the gouges out with some 150 grit sandpaper to smooth it out. Share this post Link to post Share on other sites
Rodger 527 Posted June 24, 2011 You can use reflective tape to repair a cutting strip . Share this post Link to post Share on other sites
Rodger 527 Posted June 24, 2011 yeah , there is a " 10 easy/cheap repair list " I read & posted/linked here . I can't find it anymore , but that was 1 of the easy cheap fixes it listed . Share this post Link to post Share on other sites
