benedettij
What the different between MH720 and Refine GoldCut ------ Vinyls Cutter 24"
Hi
I have a MH-720 and work perfect..... but I want an another better cheaper plotter....  :thumbsup:
I have this doubt between these plotter, and another questions......
- I can buy a Refine GoldCut without stand?:thumbsup:
- What is the lifetime of MH-720, with ocasinally used (example 2 hours per day)
Regards  :)
J_Benedetti
I was told that the goldcut is better built and more reliable than the refine.
Life of teh refine is anyone's guess. 4 years and going strong in my case.
but tthey are both made by Refine?  ?
but tthey are both made by Refine?:thumbsup::huh:?
yes, but I think the goldcut is made to stricter standards.
HEY GUYS PROB NOT THE RIGHT PLACE BUT WAT CUTTER DO YOU USE IN SIGNBLAZER FOR THE GOLDCUT 48" CUTTER I CANT FIND THE GOLDCUT OR REFINE new to the site and sign making
The Refine MH series should be there, depending on which version of Signblazer you downloaded or try Redsail
hey thanks for the reply im using signblazer elements ver6 no rfine listed and tryd all the redsail and still wont cut im useing the usb if that helps narrow down wats wrong
hey guys thanks for the help got it working so another quike question done a test word works fine real nice clean cut so im happy but when i go to cut the word stays in the bottom left corner so it be right were the blade starts how do you move it cuz i hav lots of vinyl with bit missing due to trying to get it working so i left it on the roll rather than have loads of small bit everywere thanks for reading and thanks in advance
You don't move the word, you move the cutter head and set your origin button there on the vinyl. Then it will cut there
