gpau 0 Posted July 26, 2010 hello because when I gave the order to cut the program signcut I cut around the rectangle, one side remains uncut thanks Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted July 26, 2010 probably one side is outside of the cutting area Share this post Link to post Share on other sites
gpau 0 Posted July 26, 2010 please where are the settings of one side or outside of the cutting area Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted July 26, 2010 http://forum.uscutter.com/index.php/topic,17489.0.html Share this post Link to post Share on other sites
hockeygirl 30 Posted July 26, 2010 Are you talking about the weeding box, with the final side not cut when you're cutting single? I think you have to select Refine for your cutter and it'll work. I don't remember exactly, since I no longer have a Refine or Signcut anymore. Share this post Link to post Share on other sites
CRD 9 Posted July 27, 2010 Are you using correct driver for the machine? What are you using and what is your settings? Paco Share this post Link to post Share on other sites
apscofield 0 Posted July 29, 2010 Hockeygirl is right. I have a USC MH721 and had the same problem. I changed the cutter from a US Cutter MH721 to a Refine 1 HPGL and it works like a charm now. All jobs cut and finish properly. A~ Share this post Link to post Share on other sites
