tomcat17 0 Posted July 12, 2010 Can someone tell me how to import an eps from coreldraw x5 into signblazer.Thank you very much for the help. Share this post Link to post Share on other sites
CRD 9 Posted July 12, 2010 You have to EXPORT not SAVE AS in .EPS format that is all. Paco Share this post Link to post Share on other sites
kevinjplee 0 Posted July 31, 2010 I also have same problem. I am trying to cut a simple graphic and when I try to cut in SBE I get a message: "This drawing contains a bitmap. Only other object will be cut and the bitmaps will not be cut" I have saved/exported in AI/EPS and just about every other file format but still cant get past this message I use CorelDraw 12, Adobe Illustrator 9 and SBE Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 31, 2010 then your file is not totally vectorized, raster images will not work. Share this post Link to post Share on other sites
deth502 39 Posted July 31, 2010 then your file is not totally vectorized, raster images will not work. +1 merely saving it as an eps DOES NOT make it a vector image. Share this post Link to post Share on other sites
kevinjplee 0 Posted July 31, 2010 What is the best programme to make a vector file with and how? As you can most probably tell I am a newbie so all suggestions welcome Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 31, 2010 www.inkscape.org is Free software that many people use... there are several videos and tutorials in the inkscape thread. http://support.uscutter.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=31&nav=0,9 Share this post Link to post Share on other sites
kevinjplee 0 Posted July 31, 2010 Thamks for info on Inchcape. I already have this programme but was put off by steep learning curve, but link you provided was great. Learnt more in minute or so thani have on my own in 3 months! many thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 31, 2010 your welcome also videos at the top of the inkscape thread made by forum members to help out. Share this post Link to post Share on other sites
deth502 39 Posted August 1, 2010 indeed, i surely would still not be able to do anything constructive in inkscape if it werent for the videos and posts here. signblazer, otoh, is much more intuitive just to get going with, but if you also look for info on it here, you will also be able to do a lot more things with that too, making it much more useful. Share this post Link to post Share on other sites
