tuba4 0 Posted December 20, 2007 how do I put a silhouette behind lettering in sign blazer and what is it called. I've been just making it bigger and printing it black and them smaller and inserting the color required. Is this right? Thanks much Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 20, 2007 its called shadow and Jerry can tell you best how to do it. I'm not at my SB computer right now and I trsut NOTHING to memory. Share this post Link to post Share on other sites
Jerry Bonham 1 Posted December 20, 2007 Hello, Can you give me an example of what you are trying to achieve and i will then post the instructions? Jerry from SignBlazer. Share this post Link to post Share on other sites
tuba4 0 Posted December 20, 2007 I DON'T HAVE A JOB, HOWEVER I KNOW IT WILL COME UP SOON AND I WANT TO BE READY WHEN IT HAPPENS. HERE IS AN EXAMPLE. THANKS, JERRY EXAMPLE.pdf EXAMPLE.pdf Share this post Link to post Share on other sites
Jerry Bonham 1 Posted December 20, 2007 Hey, I was expecting something complex and difficult. This is the simplest shadow possible. How to do it 1. Type Text 2. Select Text 3. Click on Shadow tool 4. Right Click on screen 5. Choose Block Shadow 6. Move the outline to the left to emulate the one in the PDF file 7. Press select. All done/ Then undo and try perspective and move the shadow to different positions etc You will be amazed at the shadows you can produce. Then if you are the proud owner of SignBlazer Pro you can produce thousands of different shadow combinations. Jerry from SignBlazer Share this post Link to post Share on other sites
tuba4 0 Posted December 23, 2007 Thanks, Jerry. I'm on vacation right now but I took my computer and will practice with it between having fun. You guys are better than any book and help line you can connect. Much thanks. Captain Alan Share this post Link to post Share on other sites
