nav255
URGENT HELP NEEDED!! MH721 KEEPS STOPPING IN THE MIDDLE OF MY CUT
Thanks!  My problem is not consistent...some large decals are fine and others are not.  I even cut the same decal two times in a row (and shut the cutter off in between)...the first time was fine and then it took 3 or 4 tries before I could get it cut again.  Does that still sound like a memory issue?  Also, anyone know which usb adapter would work for the mh721?  Thanks so much.
This is the one I'm using with my 721 and xp... no prolbems sence I got it http://www.google.com/products/catalog?q=serial+to+usb&rls=com.microsoft:en-us:IE-SearchBox&oe=&um=1&ie=UTF-8&cid=14565954588677202805&ei=SWsMTJWLBJyUMtesgbYE&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CEEQ8wIwAw#
MM64  :thumbsup:
I finally got around to ordering the above usb adapter - it looks like I need an additional cord to make it fit the machine?  I must be missing something here - can anyone help?
Thank you!
didn't you get a serial cord with your cutter?  if so, connect THAT to your cutter, then connect the new cable to that cable.  Give that try.
not on the same job - sounds like static in the stand - but you also got that covered so Next I would try the serial connection
+1  9-pin Serial connection would help.
