vianyl 1 Posted May 18, 2010 For some reason my cutter wont finish cutting words and shapes it always leaves a little spot where it didn't cut like complete, I forgot the setting to change so it will, any help? Thanks in advance! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 18, 2010 try adjusting your blade offset. Share this post Link to post Share on other sites
vianyl 1 Posted May 18, 2010 That's what it is. Thanks! Any chance on how to do that in SBE? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 18, 2010 yes, it is in the cutter set up in Signblazer. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 18, 2010 your welcome, hope it works out for you. Share this post Link to post Share on other sites
flamer 0 Posted May 18, 2010 For some reason my cutter wont finish cutting words and shapes it always leaves a little spot where it didn't cut like complete, I forgot the setting to change so it will, any help? Thanks in advance! I also found that enabling overcut pays dividends too. Not sure if thats available in SBE but it is in flexi. Overcut basically tells the cutter that where the cut line stops continue on cutting for 0.xxmm after that point to ensure all cuts are closed. Share this post Link to post Share on other sites
vianyl 1 Posted May 19, 2010 I don't think you can do that in SB I didn't find it in the cutter settings Share this post Link to post Share on other sites
