mabscotthandyman 1,410 Posted May 7, 2010 todays install not vinyl but formed plastic letters Share this post Link to post Share on other sites
Guest kenya Posted May 7, 2010 Very cool.... I'm getting some info about formed plastic letters after going to the ISA expo. It's something different to offer customers. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 8, 2010 www.geminisigns.com/index.htm here you go Kenya good profit in formed letters Share this post Link to post Share on other sites
Guest kenya Posted May 8, 2010 www.geminisigns.com/index.htm here you go Kenya good profit in formed letters Thanks Dan. Share this post Link to post Share on other sites
Guest Marek Posted May 9, 2010 Nice . How do you mount those ? Contruction adhesive (ie . Liquid Nails ) ? Share this post Link to post Share on other sites
Truckntran 0 Posted May 10, 2010 Saw a recent article about mounting them, drilled holes accept the studs on the letters, fill with silicone or other adhesive and press in place. Share this post Link to post Share on other sites
cohort 0 Posted May 10, 2010 Nice . How do you mount those ? Contruction adhesive (ie . Liquid Nails ) ? It took a bit of searching, but I found some videos on the subject: http://www.youtube.com/view_play_list?p=C44ECC85FEA1D2F9 Share this post Link to post Share on other sites
jwalters69 0 Posted May 10, 2010 I have innstalled and un-installed these in the past. I think they are great! I would buy them with the template. Tape template up drill holes at all of the"X"'s, remove template. Talk all letters out, screw studs in. Test fit. Should fit fine. Once fitted place silicone on studs and press into place. Look great and reasonably priced. Done. Intalls went well, except for one that I had to drill 100+ holes into cement 2.5 stories up... Jim Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 12, 2010 Yes you drill holes and mount with pads,with silicone would advise to use construction grade silicone, and always pay for the pattern and use it some brick can be a pain in the butt on this job i used 33 carbide tipped percusion drill bits Share this post Link to post Share on other sites
midwaste 4 Posted May 12, 2010 some brick can be a pain in the butt on this job i used 33 carbide tipped percusion drill bits Holy sh*t, bet they loved that bill... Share this post Link to post Share on other sites
