nels0359 0 Posted April 14, 2010 I've been contemplating purchasing a vinyl cutter for my business, and I believe it is going to be a necessity soon. I am looking for guidance on what type of equipment I should consider. We manufacture various types of fishing tackle and use holographic vinyl tape to finish lures. The material comes on rolls up to 6" wide (although I may be able to get wider by special order.) The pieces we cut range from 1/2" x 3" up to 1.5" x 6". We currently cut-out hundreds of these by hand, and it will soon be thousands. I have looked into getting die-cuts, but die costs are just not worth it. Looking at the short-term, cost is an issue. I would like to get into something entry-level and learn a bit before getting too invested (under $1000.) By next year, cost won't be a factor, so upgrading wouldn't be a problem. What type of cutter would be a good starting option? Thanks, Paul Share this post Link to post Share on other sites
bamafan2277 50 Posted April 14, 2010 US Cutter has some good budget models. They are doing away with the Pcut which is what I have and its a good cutter and would probably handle what you need now. If you could spare a little extra cash I would go for a Graphtec for around $1400. That will do you soo much better and you will be able to expand and maybe produce some of your own marketing materials. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 14, 2010 they are still showing laser pointers in their Memphis store, and 1 refurbished Pcut, maybe give them a call. http://signuniverse.com/index.php/vinyl-cutters/vinyl-cutters-value.html http://signuniverse.com/index.php/vinyl-cutters/refurbished-machines/refurbished-creation-pcut-24-cutter-plotter-without-stand.html Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 15, 2010 for your needs I would lean heavily toward this cutter for 900 15" Wide-CE5000-40 (CraftROBO Pro) http://www.uscutter.com/Graphtec-CE5000-Series-Vinyl-Cutter_p_125.html You will never regret getting the graphtec even to start with - this is a 15" cutter that fits what you are looking for and graphtec is far above the rest - In your situation you do not want to be messing around much with set up and the graphtec excels at working out of the box without a lot of adjusting. with an extra 60.00 order a set of cleancut blades from cleancut and you are in serious business Share this post Link to post Share on other sites
