gprockhill 0 Posted March 20, 2010 I am having a tough time with my first weed using apparel vinyl. What I realized is that some of the letters are not cut completely. Causing the weeding to be a BEAR. Is there a way to adjust the pressure of the cutting blade? Should I try this? Would I also slow down the cutting if all the letters are not cutting cleanly? Using: PCut and Cutting ThermoFlex Plus vinyl. Thanks in advance! Share this post Link to post Share on other sites
jhelms 5 Posted March 20, 2010 I dont know about thermoflex but you adjust pressure by turning pcut on letting it come on line pressing the on line button you should see the x and y, hit mode there you should press until you find pressure set your desired no. hit pause 1 time that will put you back to x and y then hit on line button and you should be back on line then cut Good luck jhelms Share this post Link to post Share on other sites
gprockhill 0 Posted March 20, 2010 Thanks! I see 'PRESS' I am assuming that this is short for PRESSURE. I will try this. Thanks. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 21, 2010 usually an incomplete cut on p-cut is fixed with slight change to the offset - in some programs there is also a overcut feature Share this post Link to post Share on other sites
gprockhill 0 Posted March 21, 2010 Is the off-set changed in the cutting software? I do not see an off-set in the menu of the PCut cutter itself. And... would that change be upward or downward? I would guess downward. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 21, 2010 most offset is in the cutting software, You do not state what cutting software you are even using.. In Signblazer it is on the cutter setup. If you would take the time to read the newbie maunual, You would be alot better off. You need to walk before you run. There is a learning curve to it all. You just can't turn your machine on and expect it to do what you want. You have to fine tune your machine for different cuts and material. Or you will be wasting alot of vinyl. You should be fine tuning and doing test cuts before you ever attempt to do a REAL design. just my 2c Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 21, 2010 here is a guide for using the offset feature - I do not have a p-cut any more and can't remember where the setting is Share this post Link to post Share on other sites
gprockhill 0 Posted March 21, 2010 Thanks Dakotagrafx ! Much appreciated for the information needed that was NOT in the manual. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 21, 2010 referring to this manual, In the Instructional thread There is alot of great info there for people just starting out. MANUAL FOR NEWBIE HOW TO START FROM NOTHING TO FIRST CUT. http://forum.uscutter.com/index.php/topic,17489.0.html Share this post Link to post Share on other sites
CRD 9 Posted March 22, 2010 People when sign in fresh at this forum should not read the forum rules about posting but should be forced to download and fully read the new bie manual first. :thumbsup: Paco Share this post Link to post Share on other sites
