Dragracer
Bexier tool
This may be a dumb ?? but can I use the bezier tool to trace a pic then go path and vectorized and save as ??
Thanks for your help .
Kevin
why do you want to do it this way? Inkscape will trace if fr you,automatically.
To make all the lines darker /maybe easier for vectorizing ?
Just a thought .  :huh:
Kevin
Or maybe use a pen  tablet ? :-
try this....once you vectorize, remove the original bitmap or whatever,leaving the traced image. DO NOT SAVE yet...go to PATH then OFFSET. It should make the lines thicker. Just keep doing it til the lines are the way you want.
THEN save as.
in FLexi Beizer Does vectorize ......... For onr color bitmaps I import into flexi .....then select the bitmap and then beizer and volia ...its vectorized.......... dont know if there is a difference in Inkscape however ....
Thank you everyone for the help ,I just would like to learn as much as I can.
Haven a blast with this vinyl cutting stuff.  :huh:
Kevin
