JLDesigns 1 Posted February 14, 2010 Curious on when using the Sunie press, should the handle stay down during the time of pressing? For some reason mine won't lock down when pressing and curious if someone could give me some insight into this. Thanks! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 14, 2010 either too much pressure or not enough - if the handle goes parallel to the work surface then add pressure Share this post Link to post Share on other sites
JLDesigns 1 Posted February 14, 2010 Even after adjusting the pressure like you mentioned still not locking. Also, my top platen is wobbly no matter the pressure...is this normal? Share this post Link to post Share on other sites
CyberSultan 6 Posted February 14, 2010 I would contact Sunie if the handle isn't staying down. I haven't seen anyone ever report that issue in this forum regarding that happening, but it does come with a warranty. The top platen is normal as it needs to be able to move. Share this post Link to post Share on other sites
Guest manwayvan Posted February 14, 2010 Hey I received my sunie the day before yesterday. Is there a way to know how much pressure to use since there is no digital display for pressure. It still sounds like your pressure isnt set properly enough to lock.It does require a lot of downward pressure on the handle to get it to lock too. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 14, 2010 when down it should not wobble at all - if it does still too much pressure - but if you cannot get the handle all the way down then I would guess it has too much pressure to get to the locking point Share this post Link to post Share on other sites
CyberSultan 6 Posted February 14, 2010 The top platen definitely should not be moving while pressing. If it's moving when the handle is down, the top platen needs to be adjusted in order to make proper contact with the lower platen. Share this post Link to post Share on other sites
