bowhunter012004 4 Posted December 22, 2009 Instructional video made for beginners on how to vectorize an image and cut with sign blazer. Quick video, nothing fancy. I took an image off the forum and vectorized it quick. Hope this helps anyone having trouble vectorizing an image to cut. Just took a basic image that someone had posted. I didnt get fancy or do anything crazy. Just a plain outline of how to. Also posted this in vectorizing category. 4 Share this post Link to post Share on other sites
CRD 9 Posted December 22, 2009 Wonderfull. Which software you recorded? Jing? It seems to run smooth. I tried some videos to make too of contour cut with SC PRO but is seems not to run smooth. Paco Share this post Link to post Share on other sites
deth502 39 Posted December 22, 2009 excellent video!! one thing i noticed though, when you resized it in sb, if i followed correctly, you wanted it 10x10, so you set the workspace to that and resized it to the workspace. i find it easier to just select the object, and type in the dimensions i want on the bottom. Share this post Link to post Share on other sites
Jay2703 704 Posted December 22, 2009 Great job. You show how easy it really is. Jay Share this post Link to post Share on other sites
bowhunter012004 4 Posted December 22, 2009 Thanks, maybe it will cut down on the confusion of how to vectorize. I used snagit 5.02. I tried in Jing but it would be choppy, and save in some goofy file name. Share this post Link to post Share on other sites
cutme 5 Posted December 23, 2009 excellent video!! one thing i noticed though, when you resized it in sb, if i followed correctly, you wanted it 10x10, so you set the workspace to that and resized it to the workspace. i find it easier to just select the object, and type in the dimensions i want on the bottom. after resizing using the above method, i use the align tool to send the graphic to the center of the workspace. bb Share this post Link to post Share on other sites
CRD 9 Posted December 23, 2009 Bowie, Snagit does not do video only screenshots or am i Wrong? Paco Share this post Link to post Share on other sites
bowhunter012004 4 Posted December 29, 2009 Bowie, Snagit does not do video only screenshots or am i Wrong? Paco snagit does video. Share this post Link to post Share on other sites
jeremySI 18 Posted December 30, 2009 id also note that no matter how good an image looks there is cleanup needed after vectorizing 99% of the time Share this post Link to post Share on other sites
quadi 0 Posted April 8, 2010 I have watched this video several times, but am not able to see what is happenng becaue the print is so small, and the demonstration is way too fast for begiiners. I would like to be able to vectorize my own clip art. Any suggestions? Share this post Link to post Share on other sites
cutme 5 Posted April 8, 2010 I have watched this video several times, but am not able to see what is happenng becaue the print is so small, and the demonstration is way too fast for begiiners. I would like to be able to vectorize my own clip art. Any suggestions? if you click on the video above twice, it will take you to youtube where you can view it full screen. bb Share this post Link to post Share on other sites
sniderman 8 Posted May 6, 2010 big help thanx for the video its awsome Share this post Link to post Share on other sites
tinaski 11 Posted May 17, 2010 do you mind posting that vector - i just would like to take a look at how clean everything turned out thanks Share this post Link to post Share on other sites
BamBam82 1 Posted February 24, 2012 Ok I followed these steps and nothing showed up on my SB screen after I clicked the scanner button. What am I doing wrong? Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted February 24, 2012 Ok I followed these steps and nothing showed up on my SB screen after I clicked the scanner button. What am I doing wrong? step by step instructions. make sure you delete the original image before saving as an .eps http://support.uscutter.com/index.php?/Knowledgebase/Article/View/147/9/how-to-create-vector-images-with-inkscape Share this post Link to post Share on other sites
