mailman 1 Posted December 15, 2009 I hope someone can help. I am trying to cut this file , all cuts fine, except the circle around the name and number, I want the circle to meet the body of ball player, but it cuts thru the ball player. I tried to group it but still cuts thru. Thanks, Mark Share this post Link to post Share on other sites
JoeBlow 5 Posted December 15, 2009 Check you have no open paths in your graphic, and also check that the circle is converted to curves. Joe Share this post Link to post Share on other sites
Mr Peabody 0 Posted December 15, 2009 If you have them grouped, ungroup them and clear the selection. Select the baseball player then - On the "Shaping Tab" select the drop down and pick "Weld To" Then select the baseball. This should clean up the extra arc. To verify that is has eliminated the "extra arc" switch to the wireframe mode. Share this post Link to post Share on other sites
mailman 1 Posted December 15, 2009 Thanks a lot . Mark Share this post Link to post Share on other sites
