ryan8281 0 Posted December 12, 2009 Well i have taken the heat gun and removed all the old vinyl on the sign. But of course it left the vinyl adhesive on there. Anybody have any suggestions on what i can use to remove it with without messing up the plastic? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 12, 2009 Rubbing alcohol, goo gone, rapid remover. . . Share this post Link to post Share on other sites
latitude42 5 Posted December 13, 2009 Mineral spirits... try it on a corner first... goo gone tends to soften the plastic, it has zylene in it... Larry C Share this post Link to post Share on other sites
neron15210 10 Posted December 13, 2009 Fellers are selling great product for vinyl removing . It's called vinyl off. I've used on on of my last projects and it worked great. Share this post Link to post Share on other sites
ryan8281 0 Posted December 13, 2009 i tried the vinyl off on it. that stuff pitted the plastic every place there was cracks in the vinyl. Luckly it was a practic peace. we tried brake cleaner just to see what it would do on the practice peace, it took the adhesive of great, so we thought lets just leave it on there alittle longer to see what happends, you know like what mith busters would do lol. Yep melted the plastic hehe. Well rubing alcohol takes it of prety good, but does take some elbo greese. Thanks all. Share this post Link to post Share on other sites
midwaste 4 Posted December 13, 2009 Try some denatured alcohol, it tends to work better than standard rubbing alcohol. Next time, just replace the signface.... Share this post Link to post Share on other sites
jhelms 5 Posted December 13, 2009 91percent alcohol all i use will not mess up anything buy local walmart jhelms Share this post Link to post Share on other sites
midsouthprosigns 0 Posted December 13, 2009 i use rapid remover from fellers its citrus based Share this post Link to post Share on other sites
neron15210 10 Posted December 13, 2009 As name says it is for vinyl , so you should spray it only on vinyl , wait a few minutes and pill vinyl off. Vinyl off brings elasticity to vinyl s it is easier to remove it in big pieces. There is also another product for adhesive removing named "adhesive off" I use alcohol a lot for cleaning surfaces and removing adhesive, but when I have big area to work with I'm using one of produts mentioned abov. Good luck Share this post Link to post Share on other sites
