Kysmiley 0 Posted December 7, 2009 I am not sure of this has to do with my signblazer or my cutter the MH 751. I am doing signs two sided, but can only cut one side at a time. If I set it to cut two copies the first cut goes ok but the second copy starts at the point of origin and it is off from the first copy about two inches. How can I get two or more copies of the same cut done with out having to sit infront of the PC andcutter to do it manually? Pat Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 7, 2009 in the cutter set up page is the advance page after cut checked? Share this post Link to post Share on other sites
Kysmiley 0 Posted January 7, 2010 I have the advance page after job checked, then there is an item right under that which says gap between jobs, this is set at 1.0 What should it be? I really need to get this figured out so i dont after continue setting after each layout has been cut. Pat Share this post Link to post Share on other sites
deth502 39 Posted January 7, 2010 i dont know if theres a setting for this to do it from the pc, but yes, thats what mine does. i just have to get up off my ass and set my new origin after each cut. Share this post Link to post Share on other sites
