amlow 0 Posted December 6, 2009 When I inseart new vinyl film rolls to the cutting plotter I can see horizontal lines of airwaves. that happen even before I even start working with the plotter, and sometime during the cuttting work. that problem cause to the final work not to look accurate Any Idea? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 6, 2009 you should put more info,, what is airwaves? describe. what cutter?, what vinyl? can't help you without info. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted December 6, 2009 I know what you mean and that usually only happens with cheap vinyl. Share this post Link to post Share on other sites
Rodger 527 Posted December 6, 2009 I have 1/4 turn mosiac metallic that tunnels ( seperated from the backing paper ) . I have cut decals thru the tunnels & it comes out great most of the time . If a section is tunneled very bad , I cut that out & use it to make smaller decals . Seems the roll ( 30 yards ) did that more as it got older , but it may be that it does it as the roll gets smaller A buddy who has been making vinyl decals for over 30 years told me to unwrap several yards , but I rolled it tight & used a rubber band to keep it that way . Share this post Link to post Share on other sites
amlow 0 Posted December 7, 2009 airwaves = air ripples that horizontally appear on the vinyl sheets(randomly i must say). I use 11 yard, 24" vinyl film rolls from china. BannerJohn is right because it is cheap vinyl. when I told them about this problem they said I need to re-debugging my cutting plotter. Share this post Link to post Share on other sites
Guest sciondrgn Posted December 7, 2009 Yeah thats what most folks call tunneling, I have a roll of chrome that does that.. What I do Is cut off the sections i need size wise and not run the roll through the machine and I dont have any problems. Share this post Link to post Share on other sites
amlow 0 Posted December 8, 2009 Thank you for you help , I will definitely try that. Share this post Link to post Share on other sites
jhelms 5 Posted December 9, 2009 I buy some vinyl local by the yard and they wrap sometimes in a very tight roll and when they do that i have tunneling but i work mine out pushing it to the closer end, never no problems on rolls of vinyl jhelms Share this post Link to post Share on other sites
