jmoney 0 Posted November 9, 2009 Have a mh 721 laptop died so trie installing on desktop using xp and SB through usb when I send to cutter it just goes through cut on the screen. Done a test cut on cutter and it is working fine. Share this post Link to post Share on other sites
Guest HowardI Posted November 9, 2009 Open signblazer. Click the cutter button. Click the setup button. Please tell me the contents of the top 2 boxes. Howard Irwin Support Specialist US Cutter 425-481-3555 888-298-8143 - Option 2 Share this post Link to post Share on other sites
deth502 39 Posted November 15, 2009 yup, had that quite a few times till i figured it out. check the box as described above. make sure its set to have the cutter a the correct port you have it at. for some reason mine seems to pick random times to switch that out on me. guessing it might have something to do with opening sb before i plug the cutter in?? but i havent narrowed down the exact reason yet. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 16, 2009 yup, had that quite a few times till i figured it out. check the box as described above. make sure its set to have the cutter a the correct port you have it at. for some reason mine seems to pick random times to switch that out on me. guessing it might have something to do with opening sb before i plug the cutter in?? but i havent narrowed down the exact reason yet. exactly - plug the cutter in them open signblazer and it should be correct each time Share this post Link to post Share on other sites
Guest HowardI Posted November 16, 2009 Just let us know what those settings are so we can help. Howard Irwin Support Specialist US Cutter 425-481-3555 888-298-8143 - Option 2 Share this post Link to post Share on other sites
