osrbikes 0 Posted October 30, 2009 I got a new cpu after my old one crashed-- i bought the US cutter laser 24" last year-- had issues getting this working last time and forget what I did--- CPU is using windows Vista-- need togo with USB -- can't get them to connect-- I am using signblazer 2008 (also can't find my auth code for reinstall) Need help-- gotta get stickers cut. Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 30, 2009 you do not need a code to install Signblazer, it is free software,, You can download it on the US cutter EBAY ads or right here on the forum. Share this post Link to post Share on other sites
YadirellT 0 Posted December 22, 2009 When you are setting up your cutter, check your Device Manager to see which COM port your cutter is connected to. When you find this out, go to your Signblazer cutter setup, and make sure the Output Device setting set to this COM Port. Share this post Link to post Share on other sites
Guest HowardI Posted December 24, 2009 The signblazer you can download from our support site is patched so that it operates as an activated version. You just need to use the "trial mode" button to start the program but it's not a trial version. You are not limited in features, it won't expire, etc. Howard Irwin Support Specialist US Cutter 425-481-3555 888-298-8143 - Option 2 Share this post Link to post Share on other sites
