Racingnut 0 Posted November 3, 2007 Trying to cut a cmx file any ideas? Conversion software? Using SignBlazer / Corel Draw Thanks, Nut Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted November 4, 2007 SignBlazer can import CMX files. Just go to the menu "File" - "Import" and then select cmx for the file type. You should also be able to cut and paste from CorelDraw to SignBlazer. Share this post Link to post Share on other sites
Racingnut 0 Posted November 4, 2007 Thanks Bruce...still no worky... Looked at the file and it's a cdr, any ideas? Thanks, Nut Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted November 4, 2007 SignBlazer can't import CDR files. Your best option is to load the file into CorelDraw and then export to CMX or copy and paste to SignBlazer. Share this post Link to post Share on other sites
Racingnut 0 Posted November 14, 2007 Thanks Bruce....I was able to work the file using Corel....imported in SignBlazer and cut.....perfect! Thanks, Nut Share this post Link to post Share on other sites
