userjon 1 Posted October 26, 2009 I'm trying to merge or flatten all layers into one. How can I do that? Share this post Link to post Share on other sites
mcrimm 1 Posted October 28, 2009 I assume everything is on one layer. . Group, combine or weld Mike Share this post Link to post Share on other sites
userjon 1 Posted October 28, 2009 No, I have 26 layers and I am trying to put them all on one layer. Share this post Link to post Share on other sites
edge 67 Posted October 28, 2009 Providing the project is not locked, you should be able to highlight and drag the curves from one layer into another allowing consolidation in the object manager found under Tools. Then right click the now empty layers and delete. Perhaps there is a simpler way. Share this post Link to post Share on other sites
rodh2 16 Posted October 28, 2009 No, I have 26 layers and I am trying to put them all on one layer. Userjon, open the object manager docker, make sure the edit across layers at the top is selected. Then select layer one, go to edit select all objects, then group them together and all the curvs will be on layer one. Then you can ungroup. Hope this helps and works for you. Rod Share this post Link to post Share on other sites
userjon 1 Posted October 28, 2009 Thanks, I'll give that a try. Share this post Link to post Share on other sites
