Guest Terry
Lettering in the cold
Guest Terry
How do you people apply wet method vinyl graphics or lettering on store fronts in the cold? Or does this mean business comes to an end in the cold season?
well,that all depends. If the store is heated inside, the glass might be warm enough to apply wet. Of course,you can always use a blow dryer to make it so. I've applied to the back window of my camper when it was 45 and no problems.
Guest sciondrgn
Did a large scion logo on a scion xb and it was about 55 out.
Just laid it down and got as much water out as i could then used a heat gun on low setting to get the job done.. Slow and steady on these
Heat gun my freind, also once you laydown the work and your using like R tape or a paper based app tape, wet the outside of the app tape and wit you will be amazed.  I did large box trucks at night in 30F weather.
cold application with fluid video
I've used rapidtac2 in the freezing cold, and it does work as the video shows!
I use rapidtac 2. Just did one last night and it was about 15* out... Worked Great, My fingers on the other hand,, :D
