chris 0 Posted October 16, 2009 Hi to all !!! every time I start a new job, cutter advance for about 6 inches... I am loosing 6 inches of vinyl on every job. Can you help me to fix this issue Thanks by advance. Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted October 16, 2009 go into your SignBlazer set up > Where it says advance after cut, change it to what you want.. Share this post Link to post Share on other sites
chris 0 Posted October 16, 2009 Thank you for your support, but i already checked that and it's set to 0.0 Help !!! I've set the vinyl dimension to the exact size of the sign, same for the work space area. Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted October 16, 2009 did you put a check mark on that box to the left of where it says ADVANCE PAGE AFTER JOB. and click SAVE? Share this post Link to post Share on other sites
American And Proud 2 Posted October 16, 2009 Just a thought here, are you hitting the ORIGIN button on the cutter once you set were you want the vinyl and were you want the blade to start cutting? Share this post Link to post Share on other sites
