brian08 0 Posted October 15, 2009 Has anyone been able to get the cp-2500 to work with windows 7 Share this post Link to post Share on other sites
Guest kenya Posted October 18, 2009 Bumping this ...... I'm wondering also. Share this post Link to post Share on other sites
brian08 0 Posted October 18, 2009 i have gotten it work.... I had to use xp mode which is a xp virtual machine running on windows 7. I would rather not have to do that maybe someone will write a new driver for it. Share this post Link to post Share on other sites
mars 45 Posted October 18, 2009 What cutting program are you using? Seems like it would be a function of the drivers used by that program. I am using VinylMaster Pro 2.95 - not sure if it works, but I have heard the new version 3 does great with Win7-- it's not out as far as I know - been on the "any day now" release schedule for over a yeart I think.-- I have a CP-2500 - but still using XP - wondering what will be the problem using Win7 -Mike Share this post Link to post Share on other sites
YadirellT 0 Posted October 21, 2009 Considering that Windows 7 has not yet been officially released, you're probably going to have to run in XP mode for now. You'll probably have better luck with the driver support once Windows 7 is released. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 21, 2009 just purchase a cheap good condition xp on Ebay or somewhere, less problems, I just bought a second xp laptop for backup. XP runs so much smoother. Share this post Link to post Share on other sites
JSPEK 0 Posted October 30, 2009 bumping for more info before I order a new pc!!!!!!!!! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 29, 2010 hmmm what's the bump for? they are already running them on windows 7 sucessfully, and drivers are in the support area, just do a search for windows 7 Share this post Link to post Share on other sites
williamssignco 0 Posted April 29, 2010 Do you mind showing me I can not find it. I would really appreciate it. Thank a ton. J Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 29, 2010 show you what? please explain. Share this post Link to post Share on other sites
williamssignco 0 Posted April 29, 2010 The driver that you say is in the support area for Windows 7 and Copam CP-2500. If I understood you correctly. Thanks J Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 29, 2010 at the top of the forum is support, all you have to do it click it for all the downloads, manuals etc. http://support.uscutter.com/index.php?_m=downloads&_a=view Share this post Link to post Share on other sites
williamssignco 0 Posted April 29, 2010 Yes I have been there to that and I have search for Windows 7 in this area to no avail. I was wondering if you could point to the correct driver itself. I saw no one else had posted a driver that is why I bumped it. Thanks for all your help. J Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 29, 2010 it is there on the left in the middle, isn't that what you are wanting? FTDI Driver executable XP/Vista/7 FTDI Driver manual install (XP/Vista/7) Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 29, 2010 Your welcome ;D Share this post Link to post Share on other sites
joshlw 0 Posted July 15, 2010 okay question? Do i have to install another driver for the cutter itself other than this driver for windows 7? I installed the executable win 7 driver and after I hooked up the plotter it says no driver installed for this usb device. Do i still nee prolific driver on laptop for cutter? Share this post Link to post Share on other sites
joshlw 0 Posted July 15, 2010 okay question? Do i have to install another driver for the cutter itself other than this driver for windows 7? I installed the executable win 7 driver and after I hooked up the plotter it says no driver installed for this usb device. Do i still nee prolific driver on laptop for cutter? Got it figured out Share this post Link to post Share on other sites
