ajgarber70 0 Posted October 15, 2009 i need some help when i download fonts i can go to my documents then downloads and find the fonts i download but how do you get them to signblazer to use them.... Share this post Link to post Share on other sites
wasatchcars 0 Posted October 15, 2009 If you are using XP go to control panel there is a folder there FONTS Copy and past your new font in that folder Share this post Link to post Share on other sites
ajgarber70 0 Posted October 15, 2009 thanks i did find the fonts file under control panel but it will only let me click on copy but it dont do any thing and it dont give me an option to paste it thanks. Share this post Link to post Share on other sites
haumana 1,221 Posted October 15, 2009 you need to make sure the it's a .ttf (True Type Font). Make sure that it's not in it's zipped file. You can unzip it, place it on your desktop, then import it to your font folder. Once there, you might want to double click on the font so that a preview pane opens up, then you should be able to select it in SBE. Share this post Link to post Share on other sites
ajgarber70 0 Posted October 15, 2009 thanks a bunch that worked and it's in signblazer now. thanks....... Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 15, 2009 you need to make sure the it's a .ttf (True Type Font). Make sure that it's not in it's zipped file. You can unzip it, place it on your desktop, then import it to your font folder. Once there, you might want to double click on the font so that a preview pane opens up, then you should be able to select it in SBE. she is amazing isn't she! Share this post Link to post Share on other sites
ajgarber70 0 Posted October 15, 2009 yep coulden't have been better.very simple thanks a bunch.. Share this post Link to post Share on other sites
Rodger 527 Posted October 15, 2009 you need to make sure the it's a .ttf (True Type Font). Make sure that it's not in it's zipped file. You can unzip it, place it on your desktop, then import it to your font folder. Once there, you might want to double click on the font so that a preview pane opens up, then you should be able to select it in SBE. she is amazing isn't she! Yep , & she does great at picking winners in the MMA events ( next weeks winners ) Share this post Link to post Share on other sites
