bamafan2277 50 Posted September 23, 2009 Does anyone know where I can get some 8" round or oval magnet blanks?? Share this post Link to post Share on other sites
jhelms 5 Posted September 24, 2009 cut them with your pcut I done several jobs cutting magnets with my pct no problem round will be simple if you look under Materials/vinyl/re;setting blade to cut reflective on sept12 2009 I walked someone thru how i cut magnets on mine jhelms Share this post Link to post Share on other sites
Guest manwayvan Posted September 24, 2009 No shit.. I would have never dreamed doing this as I wanted some of those Football helmet and horn for cheerleaders..I am assuming its gonna require a 60 degree blade and alot of pressure Share this post Link to post Share on other sites
jhelms 5 Posted September 24, 2009 I use old 60 degree blades and 104 on the pressure Share this post Link to post Share on other sites
Guest manwayvan Posted September 24, 2009 Thanks for the info I found your old post and copied it. I am creating a cuttin tips document. Do you mind if I include it in it? Its for personal use Share this post Link to post Share on other sites
jhelms 5 Posted September 24, 2009 Not a problem to copy MAN! also bigfoot cutting speed i use is 10 , my magnet is .030 thickness and you can buy the blades from US cutter 12 dollars for three plus 9.99 shipping flat rate order some materials why your at it. jhelms Share this post Link to post Share on other sites
Jay2703 704 Posted September 24, 2009 You don't have to cut all the way through either. Pretty much just score the top and you can pull them apart. Share this post Link to post Share on other sites
knucklehead 530 Posted October 2, 2009 Speciallty Graphics has em already cut if you don't want to cut them yourself. Share this post Link to post Share on other sites
