guffman 0 Posted October 22, 2007 Can someone tell me how to arch text? Still new to all this. Is there a manual for signblazer? Thanks for any help on this. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 22, 2007 select the text.At the top in signblazer,find the DISTORT menu.You will have to use the arrows to bring it up/ A box will pop up. Select which method you want to use,and go from there. I'm not at the computer that has SB on it or I would be more specific. Share this post Link to post Share on other sites
kenimes 42 Posted October 22, 2007 Manual link is under the SignBlazer category, there is an online version or a .pdf you can download. To arc text, just select your text, then click on Text, then Text follow arc. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 22, 2007 Manual link is under the SignBlazer category, there is an online version or a .pdf you can download. To arc text, just select your text, then click on Text, then Text follow arc. well,if you wanna do it the EASY way... I forgot about that I don't usually do a plain arc. But my instructions work if you wanna arc in different ways,such as higher at the ends,etc. Share this post Link to post Share on other sites
kenimes 42 Posted October 22, 2007 Manual link is under the SignBlazer category, there is an online version or a .pdf you can download. To arc text, just select your text, then click on Text, then Text follow arc. well,if you wanna do it the EASY way... I forgot about that I don't usually do a plain arc. But my instructions work if you wanna arc in different ways,such as higher at the ends,etc. Share this post Link to post Share on other sites
guffman 0 Posted October 22, 2007 Just wanted to say thanks for all your help. Share this post Link to post Share on other sites
