svplaser 0 Posted August 19, 2009 hi, i am new to this forum. i have a USCutter laser point machine, which i bought recently. when i am trying to use the cut a print option using signblazer,it is suddenly crashing and giving an error messsage which says " sign blazer has encountered a serious error.do you want to save the flie." i tried reinstalling it. but it didn't work. can someone suggest me any good working solution to this problem? Share this post Link to post Share on other sites
haumana 1,220 Posted August 19, 2009 did you try to uninstall it before reinstalling it? go through the whole long, dreaded windows process ... uninstall, reboot, install, reboot, test, test, test. try it again, if necessary. it took several reinstallation attempts until SBE functioned properly for me. If it still crashes, head to the SignBlazer bulletin board on this forum and search for a different version to install. Share this post Link to post Share on other sites
Rodger 527 Posted August 19, 2009 I have had good results using the SignBlazer download from USCutter's e-bay auctions . Usually all I do is load it without uninstalling . http://cgi.ebay.com/NEW-34-Vinyl-Cutter-Cutting-Plotter-USCutter-w-USB_W0QQitemZ300332640858QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45ed386a5a&_trksid=p3911.c0.m14 Share this post Link to post Share on other sites
cutme 5 Posted August 19, 2009 hi, i am new to this forum. i have a USCutter laser point machine, which i bought recently. when i am trying to use the cut a print option using signblazer,it is suddenly crashing and giving an error messsage which says " sign blazer has encountered a serious error.do you want to save the flie." i tried reinstalling it. but it didn't work. can someone suggest me any good working solution to this problem? what specifically, are you doing? what was the last button you clicked on? bb Share this post Link to post Share on other sites
sarconastic 29 Posted August 19, 2009 I had this same issue for a while, it turned out to be a printer driver that needed to be updated. I also updated a bunch of other drivers on my pc since they were out of date too. This eliminated a lot of errors in signblazer. Kevin Share this post Link to post Share on other sites
