Jeffrey06 2 Posted August 18, 2009 This sounds stupid I'm just looking for a way to send a "Cut" to the plottor to cut the outline from around a log I make? Is this not possible with Flexi. I've been working for about an hour now driving to get it to "send" the contour. I've attached a logo with the contour, I just want to print the outline in "white" Vinyl to lay the other colors on top to make it look like a printed sticker, is it possible?? Any help would be great! Thanks. logocontour1.zip logocontour1.zip Share this post Link to post Share on other sites
Jeffrey06 2 Posted August 19, 2009 Anyone? Just need a outline of the image to lay the other colors on top of. Share this post Link to post Share on other sites
Guest fivestar Posted August 19, 2009 Why not just use the outline tool instead of the contour? BTW, no you can't do it that way. Share this post Link to post Share on other sites
JoeDirt 5 Posted August 19, 2009 ^^^that's right use the outline tool, then in the drop down box use contour and make your outline. Share this post Link to post Share on other sites
Jeffrey06 2 Posted August 19, 2009 Outline, then select contour, it will let me cut the outline. But, I have to weed out of the insides of the contour cut, every letter, etc. Is that the only way? If it is, I'll have to deal with it... Share this post Link to post Share on other sites
JoeDirt 5 Posted August 19, 2009 I couldn't open your file export it to an eps but is this just a multi color layering piece? Share this post Link to post Share on other sites
Guest fivestar Posted August 19, 2009 Make sure you have it set to "with backing". Share this post Link to post Share on other sites
Jeffrey06 2 Posted August 19, 2009 Yes it is. I'm wanting to outline the logo is white. Which I have successfully done, it's just time consuming having to weed everything on the logo. logoeps1.eps logoeps1.eps Share this post Link to post Share on other sites
Jeffrey06 2 Posted August 19, 2009 Make sure you have it set to "with backing". Where is that located at fivestar? Share this post Link to post Share on other sites
Guest fivestar Posted August 19, 2009 In the design central window. Share this post Link to post Share on other sites
JoeDirt 5 Posted August 19, 2009 here is the backing button. Share this post Link to post Share on other sites
Jeffrey06 2 Posted August 19, 2009 That was it!!! Thanks a million guys!!! Share this post Link to post Share on other sites
