pitkin2020 1 Posted August 1, 2009 I know how to change the settings in SBE to MM's now (only a few hours to find that lol) but everytime i close it and restart it starts again in Inches, is there anyway to set it to start in MM's Cheers Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 Crazy... Im not sure but you may want to try uninstalling it completely and then re-installing it and then setting it to MM and seeing if it holds! Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 1, 2009 what method did you use to change from inches to mm? Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 Good point, did you set it program wide or did you just adjust for that document...?!? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 1, 2009 Good point, did you set it program wide or did you just adjust for that document...?!? for it to remain...click on file,then workspace setup,and change it there. It should stay. If you just toggle between then when your workspace is open, it won't. Share this post Link to post Share on other sites
pitkin2020 1 Posted August 1, 2009 for it to remain...click on file,then workspace setup,and change it there. It should stay. If you just toggle between then when your workspace is open, it won't. thats exactly how i did it, but if i close the program after i have made something then reopen it, for some reason it goes back to inches again??? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 1, 2009 Funny,that. I've never had it revert back. You are clicking OK? Do you have landscape or portrait chosen? SB is funny sometimes,and an unistall/reinstall (as Brandon mentioned) is all that seems to work. One of the drawbacks of software that isn't being supported or updated. Share this post Link to post Share on other sites
pitkin2020 1 Posted August 1, 2009 very strange all day it has been reverting back to inches now its sticking to mm, how odd lol thanks for the help though guys much appreciated Share this post Link to post Share on other sites
Rodger 527 Posted August 1, 2009 It seems if you made a file using inches & saved , it comes back in that mode even if you have set the software to mm . Share this post Link to post Share on other sites
