Graphicxtasy 0 Posted September 28, 2007 I've read through this board and can't seem to find an answer to this question. I know you can use inkscape to do two layers on lettering but quite frankly I'm dissapointed with the quality that comes out of it. Does anyone know a way to get it to work in Illustrator. Strokes won't work but there has to be a way. It would be much simpler since I design everything in Illustrator and I can just send right to signcut. Share this post Link to post Share on other sites
kenimes 42 Posted September 28, 2007 Moving to Illustrator category..... Share this post Link to post Share on other sites
Guest Terry Posted October 2, 2007 I think it is under outline stroke, then path, creat outlines?. I did it once but can't remember how. I'll try it again, and post it. Share this post Link to post Share on other sites
Guest Terry Posted October 2, 2007 Type text, place stroke 4pt from pallette, click object tool, menu-type- create outline, object-path-outline stroke. I think? Share this post Link to post Share on other sites
UpNorthPromo 3 Posted October 31, 2007 When adding strokes in illustrator you may also want to open your pathfinder window, hold alt and click on the "add to shape area" button to remove all of the unwanted paths. Share this post Link to post Share on other sites
dbtoutfit 5 Posted March 7, 2008 We need to elaborate on this subject a bit more. Anyone with more info on exactly how to do this please leave info. It seems even after "simplifying" the paths you not remove the internal paths with out deleting it's internal colors. For an example: Take the letter "O" (provided you have used stroke path) after looking at the path in "path view" and simplifying the object you will see a path around the edge of the stroke (which is correct), one around the inside of the "O' which is correct but the problem comes in when you notice there are paths around the original "O" from where the offset/stroke starts from. It seems you can not remove this path without deletion of everything inside of it, thus you loose the inside of the "O". Hum.. Share this post Link to post Share on other sites
dbtoutfit 5 Posted March 7, 2008 Ok I got it. Going to cut this one out to make 100% sure and I will see if I can not post a video tutorial. Share this post Link to post Share on other sites
andy 0 Posted June 3, 2008 hello dbtoutfit, how did it go? Share this post Link to post Share on other sites
hairyconiption 0 Posted June 3, 2008 I have had a lot of problems with the internal lettering colors. It seems in illustrator after I trace out the letters, if there are multiple colors there will be an "o" or "a" with the inside a different color than the actual letter was painted.... anyone know how to overcome this? Share this post Link to post Share on other sites
dbtoutfit 5 Posted June 4, 2008 hey Andy, Joe wrote up a tutorial on it, thus why I never did one my self. Just do a search for Adobe Illustrator. Eric Share this post Link to post Share on other sites
andy 0 Posted June 4, 2008 thanks dbtoutfit, yes I saw Joe's tutorial after I sent my message to you. Helped me alot!!! Sorry hairyconiption dont know the answer to your question coz Im a new to this. Share this post Link to post Share on other sites
