jerry_13 0 Posted September 5, 2007 Hi everybody. I'm brand new to graphics and vinyl cutting. I'm just getting started and I was wondering if somebody can help me out with manipulating my clients artwork so that the art is kind of one "united" piece instead of many entities. For example, my clients artwork has some olive branches on the sides of his logo. The problem is that every leaf and every piece of the artwork is seperate, so when I try to cut it out, it overlaps and cuts every single little piece. I have illustrator 10 and I'm just learning how to use it. Can anybody help me out? Thank you. Jerry_13 Share this post Link to post Share on other sites
kenimes 42 Posted September 5, 2007 Welcome to our forums!! I am sure one of our many users might be able to shed some light on this, unfortunately I do not even have a copy of Illy, so I am not sure. Just wanted to give you a warm welcome. Share this post Link to post Share on other sites
jerry_13 0 Posted September 5, 2007 Thanks Kenimes! I'm so glad that these forums are available. I'm sure I'll have tons of questions since I'm just starting out. Share this post Link to post Share on other sites
Guest fivestar Posted September 5, 2007 Jerry you need to weld them together. I don't know what Illy calls it, but most programs call it the "weld" button. Share this post Link to post Share on other sites
jerry_13 0 Posted September 5, 2007 I'll play with the program and see if I can find a weld function. Thank you! Share this post Link to post Share on other sites
Guest Terry Posted September 8, 2007 make sure you select solid colors, go to object, group,outline stroke. Share this post Link to post Share on other sites
jerry_13 0 Posted September 10, 2007 Thank you! I still haven't had any luck, but I'll keep trying. Share this post Link to post Share on other sites
UpNorthPromo 3 Posted October 31, 2007 You'll have to play around with all the pathfinder options in illlustrator. Open the pathfinder window and click on the differnt options to get the results you want. You will probably need to use merge (weld) or add to shape area. Hope this helps. Share this post Link to post Share on other sites
Biker Scout 0 Posted November 5, 2007 Jerry, you need to select the items that you want to "weld" together and open your pathfinder pallet. It's the very first button on the top row, left hand side. But you need to hold the option button down when you click it. That makes the weld permanent. If you don't use the option key there's a little button on the right that's usually grayed out, and it says "Expand" You will need to hit that button to fully "lock in" your pieces. It's kind of a mini-undo that I know many people use, and can later go back and unlock those pieces later on for editing. I never bother with leaving the pieces only "half welded" because I just can't make myself do it. If I'm going to click the button, I'm going all the way through with it! Besides I can always recreate anything later on. Main reason why I insist on using the "Expand" function (with option key first time) is that I cut right out of Illustrator using MagiSign. So having unwelded pieces isn't really an option. Hope that helps. Share this post Link to post Share on other sites
UpNorthPromo 3 Posted November 7, 2007 If you can send me the file I will try to get the results you want Share this post Link to post Share on other sites
