signme 1 Posted April 21, 2009 I changed the blade in my mh721 today. Now it is cutting great on the right side but when it goes to the middle it cut s through the back. I have adjusted it and adjusted it. If I adjust it so it don't cut through in the middle then it dont cut all the way through the vinyl on the right side. Stomped any suggestions would be great! Thanks Share this post Link to post Share on other sites
tlzimmerman 11 Posted April 21, 2009 make sure your carriage is on the track Share this post Link to post Share on other sites
signme 1 Posted April 21, 2009 I did check and it is on the track thanks Share this post Link to post Share on other sites
kenimes 42 Posted April 21, 2009 Think we spoke earlier today, and you went and purchased an authentic Roland blade, and it sholved the issue. Was that you? Share this post Link to post Share on other sites
signme 1 Posted April 22, 2009 Yes it was Ken. Thanks for the help! Share this post Link to post Share on other sites
jeremySI 18 Posted April 22, 2009 i saw the nonauthetic roland blades on ebay and thought about getting them then i was just like nahhhhh ill just stick with whats known to work Share this post Link to post Share on other sites
kenimes 42 Posted April 22, 2009 Seems he is still having the issue, even with the actual Roland blade now, so it is probably related to something on the carriage assembly. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 22, 2009 I have used the Roland compatable blades for 3 years without a problem. However, a few weeks ago the same thing happened to me. New blade, awful cuts. I removed the blade and it was slightly longer than the rest of the blades I had. Tossed it,no problems since. I guess you get a bad one now and then. Share this post Link to post Share on other sites
