gina0308 0 Posted April 18, 2009 I am ready to throw my Laserpoint out the window. Got my Laserpoint last week, set it up, installed SignBlazer. When I tell it to cut, it says it is sending to cutter, but nothing happens. I have the cutter hooked up to the computer with a USB to Serial Cable, because I first had it hooked up with USB to USB, from reading all the posts, it could have been the problem. I have checked the baud rate, they match up. I have unstalled everything and reinstalled. Share this post Link to post Share on other sites
avery96 0 Posted April 19, 2009 Wow! I am having the exact same problem. Got mine a week ago too. I tried to set it up today and I get the same message you do. I am however using USB only connection with my HP laptop. Very frustrating and I'm sure it's something I'm doing wrong. I'll keep searching the forum for answers. Share this post Link to post Share on other sites
gina0308 0 Posted April 20, 2009 Please let me know if you figure it out. I have tried USB to USB. I will keep you posted. Share this post Link to post Share on other sites
kenimes 42 Posted April 20, 2009 Open SignBlazer, then go to Cutter, then Setup, and let me know what you have for the top 2 selections? Now click on Comm Settings, and let me know what you have for each selection... Share this post Link to post Share on other sites
gina0308 0 Posted April 20, 2009 Under Setup - USCutter LaserPoint - Blazer Comm 8 - USB to Serial Comm Settings Baud Rate : 9600 Data Bits: 8 Parity: None Stop Bits: 1 Flow Control: Hardware Share this post Link to post Share on other sites
avery96 0 Posted April 21, 2009 Finally figured it out. For some reason my computer wanted to assign my cutter to comm 22. I just renamed it to comm 2 to match everything else and the cutter fired right up. Hope that makes sense. I just kept searching threads until it fianally clicked....... about 6hrs. later. Good luck Share this post Link to post Share on other sites
nhoffme 0 Posted April 21, 2009 I had some of the same issues using the USB port. I downloaded driver updates..thats what worked for me. Share this post Link to post Share on other sites
