metatrox 0 Posted March 31, 2009 Alright so I just bought a 15x15 Sunie press and a roll of white and black siserweed EasyWeed from USC. Do i NEED anything else? I see peeps talking about teflon sheets. Do you need them for vinyl or only like ink transfers? Are there any good starter threads here with good direction. I appreciate the help! I CANT WAIT!! I have shirt designs i've made for like cafepress and zazzle. But they cost like $25-$30 each. I'm hoping to make them for myself around $5-8 right? Share this post Link to post Share on other sites
Guest fivestar Posted March 31, 2009 Just remember CUT IN MIRROR/FLIPPED. You WILL forget to do this, I promise. ;D Yes you should be around that price range. Good forum for t-shirts is www.t-shirtforums.com and http://tbiz101forum.com (which our very own MonkeyMeMe is on the staff there ) Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 31, 2009 Like five said MIRROR - cut one wrong tonight again!! love my sunie Share this post Link to post Share on other sites
UltimateTeez 0 Posted March 31, 2009 you'll need a teflon sheet when re-pressing when you peel the mylar layer off (clear layer).. otherwise your platen will stick to the vinyl.. our heat presses have teflon affixed permanelty to both upper and lower(just a time saver.. and we're a bit lazy ) have fun.. enjoy! Share this post Link to post Share on other sites
DTFuqua 0 Posted April 1, 2009 If you don't want, can't wait for teflon sheet you can do very well with parchment paper from the bakeing department in your local grocery store. Caution. Some have chemicals but I use reynolda without any problems. Good luck. Terry Share this post Link to post Share on other sites
Guest fivestar Posted April 1, 2009 You can also use the backing paper from sign vinyl if you're in a pinch. Share this post Link to post Share on other sites
metatrox 0 Posted April 2, 2009 Thanks everyone!! I was able to add some Teflon sheets to my order from sunie. Should have the vinyl Friday and the press Monday. Guess they didn't get it out quick enough. was hoping to play this weekend. Share this post Link to post Share on other sites
sarconastic 29 Posted April 2, 2009 A little tip: From experience(cut one wrong too), if you cut a design and forget to mirror it. If it's a single color layout and for you or a friend, press the wrong one on the reverse of the shirt. makes it look like the design goes clear through. And gets peoples attention. Provided it's not printed. Share this post Link to post Share on other sites
Renegade 2 Posted April 3, 2009 Take a look at Tee Square It at http://www.heatpressessentials.com/. Pretty handy tool. I also use magic erasers to clean off my press and Teflon sheets. Weeding pick and or pointed tweezers are pretty handy for weeding. Silicone parchment paper for JPSS. Share this post Link to post Share on other sites
Fbomb 0 Posted April 3, 2009 Once I cut text for a friends hood the wrong way. I ended up cutting another the proper way and pressing one on the outside (the proper one) and one on the inside (the backwards one) on the lip of his hood. It came out pretty cool like an optical illusion. The only other thing not mentioned that I can think of is getting an IR gun to make sure your press is at the right temperature. Share this post Link to post Share on other sites
metatrox 0 Posted April 4, 2009 Thanks everyone! Yeah I got the press and the vinyl in yesterday!! I've already done like 5 shirts. Can't wait to post them and show them off. I picked up several shirts for $.99 each at a local store. Plenty of things to try. Share this post Link to post Share on other sites
