aries58 0 Posted February 6, 2009 I have noticed that in sb when I print it never stops after 1 print it will still print after one print and not freeze,but in cut it stops afer first cut freezes so I pull out usb cord and reconnect it everytime.I personally think sb and MH721 cutter are not compatible and therefore gets errors..... Share this post Link to post Share on other sites
kenimes 42 Posted February 7, 2009 9-pin Serail connection, and this problem goes away. The problem is with Windows and the USB driver- not the cutter and the software. Share this post Link to post Share on other sites
Dylan 0 Posted February 7, 2009 I had similar problems with usb, after switching to serial, the cutter is rock solid reliable, with usb it was about to drive me f***ing crazy. NOT ONE GLITCH since switching to serial, you can get a serial card for about twenty five bucks or less at newegg.com, if your computer doesn't have one. Share this post Link to post Share on other sites
aries58 0 Posted February 7, 2009 9-pin Serail connection, and this problem goes away. The problem is with Windows and the USB driver- not the cutter and the software. Thanks Share this post Link to post Share on other sites
