unkes60 0 Posted July 14, 2007 I just recieved the Refine cutter, Signcut x2 and inkscape. When I have any more than one image, (say text and a circle or something) and I save it as a eps (there is no ai. option) Then i open it in sign cut it will only show one image either the text or the circle. I can't seem to find the folder for sign cut that I am suppesed to export it to, like it does'nt exist; so I save as. Iv'e tried everything I can think of to fix it, I'm going nuts... Any suggestions? Also, I have tried to get clip art off of Word but it doesn't work either. Suggestions?? Share this post Link to post Share on other sites
kenimes 42 Posted July 17, 2007 I think you need to group the text and circle before saving in .eps. Go to Object, then you should see a group feature. Share this post Link to post Share on other sites
smokenjoe50 0 Posted August 15, 2007 I have this same problem. I am working with a logo. I have tried grouping that didn't work. I am using inkscape and when I try to open it with sign cut I only get the first letter of the logo. Share this post Link to post Share on other sites
kenimes 42 Posted August 15, 2007 Have you tried upgrading to SignCut 2.17? If not, I would suggest downloading the latest version. I think it may have been the resolution to a similar call I had earlier today. http://uscutter.com/index.php?option=com_docman&task=cat_view&gid=9&Itemid=5 Share this post Link to post Share on other sites
