ff-extreme 6 Posted December 10, 2008 Having a problem cutting this design customer needs the design 3"x3" and at that size everything just pulls up tried adjusting speed with no success. any advise? john and marry 2.eps john and marry 2.eps Share this post Link to post Share on other sites
kenimes 42 Posted December 10, 2008 New blade? Less blade sticking out, and more pressure? Higher cut speed, or lower cut speed? Share this post Link to post Share on other sites
Guest fivestar Posted December 10, 2008 First off I'd take out the shadows on the wedding bands..... and make the bands thicker. Share this post Link to post Share on other sites
ff-extreme 6 Posted December 10, 2008 five star a perfect opportunity for a how to! I really haven't learned to edit much in flexi hard to find good how to's Tried slowing it down i think ill try a new blade next. My copam should have no trouble cutting something this small? Share this post Link to post Share on other sites
Guest fivestar Posted December 10, 2008 No time for tutorial, but I basically ungrouped then deleted the shadows.....regrouped the wedding bands and used outline tool to put small outline. Here's what it looks like.....BTW, the fonts aren't the same in the pic you posted and the eps. This is 3"x3".........cut at 8 IPS on my refine. John.eps John.eps Share this post Link to post Share on other sites
ff-extreme 6 Posted December 10, 2008 Thanks five, what size did you cut it at? Sorry about the fonts I was playing with different styles. Share this post Link to post Share on other sites
ff-extreme 6 Posted December 10, 2008 Heres what it looks like when I cut it! Im gonna try a new blade Share this post Link to post Share on other sites
Guest fivestar Posted December 10, 2008 Couple things........I use a 60 degree blade and what brand vinyl you using? Oracal in my opinion works best.....If I would of used FDC then mine would of probably turned out like yours did. I gotta go out for a while and repair a computer.....so I won't be back on for a while. Share this post Link to post Share on other sites
