neron15210
vinyl on the inside of the window?
Guy wants me to install vinyl sign (8' x 16") on inside of the window.
I'm wondering if someone already tried it.
Should I do it?
Guest fivestar
Sure, you just cut it in "mirror" or flipped.
Thanks Five , I do know about cutting it in "mirror", but I'm wondering if sun will  affect adhesive  on vinyl.
Guest fivestar
No the sun won't affect the adhesive.  Alot of businesses have to use the inside method because they actually only lease the inside of the store and the landlord won't let them put anything on the outside of the windows.
Thanks Five.
                    It's  going to make my job much easier. It's kinda cold to work outside.
any air pockets would stick out like a sore thumb also, right ?
I put decals on the inside of the back window on my trucks . Install wet & air bubbles are reduced ALOT & unless scrutnized  , good .
Five star
I have read alot of people talking about wet application.
I have never tried to do because, I don't know what to use.
Will this work indoor as well as out door.
I have been doing alot of trailer lettering.
The 18" lettering can be tricky putting on.
thank you
Darrell
kearn
Guest fivestar
I use good ole tap water.......straight from the spigot.  Alot of people mix it with dishsoap and alcohol but I have best results with straight water in a spray bottle.  As for indoor and outdoor, yes you can use it either way.
