Days Won
38
Everything posted by Sue2
How're the colors holding up in the weather/sun? Sue2
AND...it's ON SALE right now for $220!
Okay about to do first shirt any advice
Sue2 replied to eprcvinyls's topic in T-Shirts and/ or Garments
I keep a copy of this chart by the heat press to help with size & placement. Sue2 -
Good job...are they spelled right? Checking spelling is actually step 2 after creating the file It wasn't that hard now was it? -
I do that too! ...you didn't mention weeding...I'm sure you meant to do that though....right? -
I first read it as "MARITAL ARTS"......wonder what that would cover!
Got my SC2 got my Vinylmater, Test cut great but how to make VM cut?
Sue2 replied to eprcvinyls's topic in VinylMaster CUT, LTR, PRO & DSR
You don't have to re-do everything...just try a bit different motorcycle graphic. Sue2 -
Wait till you get to HTV and t-shirts! -
Addicted yet? -
Ugly would be my first guess...but Find My Font says: CrEAtoR cAmpoTYPe SmcP (Regular)
I use Harbor Sales. Sue2
Anyone here use a Hix Hobby Lite Swing Away Heat Press Machine - 9" x 12"
Sue2 replied to eprcvinyls's topic in Heat Presses
Even make your own "company" shirts Sue2 -
Time to jump in and get some experience...make your family some fun t-shirts! Sue2 -
Don't worry so much about crooked/straight alignment...I mostly eyeball it too... Once you see YOUR shirt "hanging" on someone you will wonder why you were so careful! Every body is different and has different bulges and bumps....the shirts will conform to what they are covering. Centering is probably more important...... AND if you are making multiples they should all be approximately in the same position. Just my 2 cents............Sue2 -
That's under copyright protection. Hot Stuff the Little Devil is a comic book character created by Warren Kremer .
15x15" would be sufficient..... Years ago I lucked into a used Hotronics 16x20" locally.....that spoiled me! The auto-open presses are tempting! Sue2 -
MIRROR...MIRROR...MIRROR!! 16x20" is the way to go if you are buying a press...most of my shirt fronts/backs are 10+ inches wide. Not to mention those XX & XXX shirts take a bit larger graphic to look right. Shirts take a lot of steps....Design, Vectorize Design, Cut MIRRORED Design, Weed, & finally Press. BUT, shirts are fun! Sue2 -
Too small to work well with "find my Font
No, I mean converting all your text to outlines (objects) this way they will be un-editable as text but are seen as objects in VM....I assume you have no trouble with the cross outline. http://www.graphic-design-employment.com/adobe-illustrator-how-to-convert.html Sue2
I mostly use CorelDraw instead of AI....but, if I had to guess, I would ask if you converted your text to curves before saving as an eps/svg file....then importing to VM. Sue2
In search of some good kryptek like vector files.
Sue2 replied to Bclark215's topic in Graphic Requests
There are some files here in the Graphic Requests section...use the search tab. Sue2 -
Too small to trace well...not to mention the grey watermark... You will have to enlarge it and redraw/recreate it yourself. Sue2
Anyone have a ripped open hole vector for heat press on a t-shirt. Preferably just black. TIA - Sue2
Good jobS!
- 1 reply
- 1
