mailman
Posts posted by mailman
Cannot get contour or border to cut inside of letters. I can set contour around font but not the center such as on R or O. Thanks, Mark
Thanks for all the help. Mark
Thanks again for all your help. Mark
Thanks MZ SKEETER I gave it try, I set the size of test box to cut a 2"x2" square at 100% it cut a box 8"x8" . I reduced the percent to 25% and it did cut 2x2 square. My device units per inch is set at 1016 should I reduce this to 254? Thanks, Mark
My image is cutting about 4 times the size of original image. I am not sure how to calibrate size. Is there a factory setting that is standard in the device units per inch. Mine was set to 1600 units per inch.Thanks, Mark
THANKS. MZ SKEETERK. Mark
I upgraded to vinylmaster ltr , for the life of me I cannot figure out to access extra fonts. I did download the extras file. Thanks, Mark
Try tree silhouettes
Thank you very much for your help, I really appreciate it. Thanks again, Mark
Could someone help me with a default font, I choose a font , click on my page and the font reverts to arial 24pt. Any help will be appreciated . Thanks, Mark
Thank you both very much I really appreciate your help. Thanks again, Mark
probably should know this, what file type to use when e-maiingl a CDR file to someone without Corel draw. Just want include in body of e-mail. Don't know how to convert to jpeg. Can I send Bitmap and at what resolution? Thanks, Mark
Thanks Mz Skeeter, sorry it took so long to say thank you for your help, Mark
Thanks Mz. SKEETER, the job is cutting fine, I thought the cut would begin at the origin point, bottom right if I sat that as the origin point and feed as it cut, I guess things are OK. Thanks again, Mark
My last few jobs are cutting from the rear of design to front, I hope I can explain this right. I am cutting a design that is 35" I set the origin to begin cutting at the lower right hand corner, but the vinyl feeds the length of job and begins to cut pulling the vinyl back through. I am using Cutting Master 3. Thanks, Mark -
Thank you very much,sorry so late. Mark
- 1
Could someone explain to me how to create a chevron pattern in Corel x6. Thanks, Mark
Be careful a lot of artwork is copyrighted. My Vinyl Designer has a collection of interchangable stick figures for a very reasonable price. Mark
What is the difference between bass clarinet and a regular clarinet. I have a vector clarinet in my mega collection. Mark
I am using Corel x-5, when I sent simple text to sign cut, in the preview it shows cut line going thru my text, cannot figure out to get rid of them. Thanks, Mark
I can not change size of an object, or rotation of an object by typing the values in the tool bar, for size I have to go to arrange ,transformation, size. I don't know if I did something wrong in my settings? X-5. Thanks, Mark
Thanks
Mike I will check it out. Mark
corel 2017
in Corel Draw
Thanks mfatty I will give this a try. Thanks again, Mark
