Days Won
3
Everything posted by kenimes
Not sure what you mean exactly. Are you trying to cut from SignCut and it does nothing? I would be happy to double check things with you by phone. Email me directly at kenimes@uscutter.com to set up a time for me to help you. Ken
artcut settings
kenimes replied to aamotox's topic in USCutter Refine Cutting Plotter Support Requests
I believe so, I am still learning ArtCut. It is the older software we bundled with our cutters. It is taking some getting used to. -
Copam 3500 feeding problems
kenimes replied to TmEvil's topic in Copam Cutting Plotter Support Requests
The pinch rollers need to be in the green sections in order for it to feed properly. The screw on the back should not need to be adjusted. The SignCut software is strictly for cutting, and you need to import graphics files to SignCut in .eps or .ai format for SignCut to read the file properly. -
Welcome to our forums!
This cutter IS acutally a USCutter Refine. We are getting him taken care of.
artcut settings
I think I found it. When you click cut/plot a dialogue box comes up. Click on setup up top in this box and then the plotter compensation tab. Looks like it can be set in there. -
Are there issues going from serial to serial?
kenimes replied to goinpostalscottsburg's topic in Copam Cutting Plotter Support Requests
Curious to know if the PNC 960 driver got you up and running? -
SignCut LE importing from Inkscape correctly. Customer is having this issue and does not have easy internet access, so I thought I would post for her. I would have had her email me the file to test here, but no internet. Thank you, Ken
I would like to introduce myself.........my name is Ken Imes :Hello: and I am the newest addition to the wonderful US Cutter Team. If there is anything I can help you with, do not hesitate to ask. I am new and still learning the ropes, but working right along side some of the best, including Marcel. So, it may take me some time to research your issue at first :dontknow: , but rest assured, I will do everything I can to resolve it. :read: I would like to thank you in advance for your patience and look forward to working with everyone. :wav: Have a great weekend, Ken
She would be able to design her own using a graphics program. Then she could import the file to the cutting program to cut out the stencil board. Not sure if there is an actual Stencil program available, but with a graphics program and the cutting program, she would be able to do what she desires.
Excellent story about the value of a USCutter.
Great news.
I would suggest trying for the CP-2500.......one of the best we sell. Good luck.
Also make sure you rename the file you are saving. I have found that after I change the file ext. to .eps that the name of the file still says .svg I had to go and type in a new name like "test" then it saved the file as test.eps for my SignCut import folder. You also may want to upgrade to the latest version of SignCut found in our download section of uscutter.com. It is under Drivers. Ken
My Show unread posts since last visit
kenimes replied to Beardown's topic in Website and Company Feedback
Mine seems to work OK. I did a scan of the forums for errors and it came up clean. I will check into it for the both of you. -
Have had more problems!!!!!!
kenimes replied to bundownbaker's topic in USCutter Refine Cutting Plotter Support Requests
I apologize for all of the issues you have run into. You can email me directly at kenimes@uscutter.com so we can try and get this resolved. -
I would be happy to help you get it to work with SignCut, but do not know about Corel for cutting. Like billy said, I believe Corel is strictly a graphic design program and not meant to be used as a cutting program.
NOTEBOOK CARD TO SERIAL PORT
kenimes replied to arab's topic in USCutter Refine Cutting Plotter Support Requests
As Tater stated, the newest USB drivers would be my best suggestion. They seem to solve alot of communication issues when using USB. -
problems please help
kenimes replied to smokey's topic in USCutter Refine Cutting Plotter Support Requests
For assistance you can email me directly at kenimes@uscutter.com -
Cuts across graphic randomly
kenimes replied to smoovlatino's topic in USCutter Refine Cutting Plotter Support Requests
If you are using SignCut try clicking on Edit, then deleting all registration marks, weeding lines, and manual tiles before you cut. Also make sure you have the latest version of SignCut. It can be downloaded from our web site under Downloads, then Drivers. -
Well billy, I hope that is not the case. If they offered better support for their product we may have stuck with them. The solution for now is to use SignCut instead of ArtCut. It will take some getting used to, but it is a more reliable program.
I am not sure why you have not got a response. We try to answer each and every email sent to us. I am not in the office until tomorrow, at which time I will look up the info. you requested. Please email me directly at: kenimes@uscutter.com with your eBay auction item number so I can look up your tracking number and respond. You may also email me directly if you ever have an issue with your cutter. Happy Easter, Ken
