Wildgoose
Super Moderators
  • Content Count
    6,535
  • Joined
  • Last visited
  • Days Won
    293
Everything posted by Wildgoose
  1. Wildgoose
    mesh jerseys?
    I've never had any problems with them. They sometimes have thick seams so you might make sure they aren't holding the platen up. I use a pressing pillow if the seams are going to play a factor.
  2. Wildgoose
    Tracking
    If you try out a free week of SignCut Pro and use the step-by-step cutting feature you will be fine. You tell the cutter how far to go at a time and it will cut everything in that amount of distance. I wouldn't use it on a whole bunch of text but for long simple stuff it will help your tracking issues. After you push the cut button it takes you to another screen where you can preview and it will run a little demonstration of what it is going to do and you can watch to make sure it's stopping in good spots and make adjustments. I used to have it stop about every 12" on my P-cut and that kept everything nice and tight. Sometimes you can get it to stop right between letters sometimes not but it will help a LOT. One of the best features on the program for budget cutters. I don't use that feature any more with my new cutter but it saved my bacon several times in the old days. If you input the size of your material it will layer it for you too if you need. also has registration marks but I usually make my own for that and with the value cutters I didn't use the weeding lines because the cutter wasn't accurate enough to keep from gouging into the work.
  3. Wildgoose
    Looking for a hibiscus
    Here's one I have that has a small volleyball in there you might have to remove. Pic is 90* off Hibiscus VB.svg
  4. I had about as much trouble with my teflon developing wrinkles as anything. Maybe I need a better storage spot but my teflon sheet ended up with a lot of small wrinkles that you can see in some colors so I ended up punching holes in the edge and using it for a lower platen cover on my back-up press and just use either parchment paper from the kitchen or Kraft paper I bought from Stahls when I first started up. It lasts a long time and works well.
  5. Wildgoose
    how to do arch writing over picture
    I think it can be done but I also think you would be better off downloading Inkscape and designing with it. It is a free open source vector program that will work circles around SCALP. Then just use SCALP to cut it. There may even be a SCALP plugin for Inkcsape.
  6. Wildgoose
    Stick Family Sign
    I second the 3M VHB but you won't be getting it off very easy it ever. If it's light weight I would try some banner hem tape. You might consider centering the vertical text.
  7. Wildgoose
    Vinyl for High Heats
    My day job is roadwork. My current company doesn't pave but I have worked for several paving outfits over the years. Hotmix is usually loaded out around 325deg. It will cool down some while in transit but is usually still in the neighborhood of 290-300, I doubt that the sides of the hopper would get clear up that hot but I bet 200 to 240 would be likely once in a while. I wasn't in the vinyl business back then but I seem to remember vinyl on our paver hoppers that seemed fine. Maybe it was painted but I doubt it.
  8. Wildgoose
    When installing layers
    I don't use wet very often unless it's big or complicated either by the shape of substrate like a curved rear window or complicated as in layered with lots of very precise overlaps. If I think I can handle the size by myself or if I have an extra pair of hands to keep from having an accidental corner touch I do it dry. You can even pop up a small mishap dry if your quick and do it with a good snap. If I have a long run of text that's not script I top hinge and cut it in sections and just do however much I think I can tackle, like two or three letters at a time if they are big. That's my $0.02 anyway. Wet is just a little slower and a little more mess to clean up but it's definitely safer too. (Also don't try it with clear app tape.)
  9. Wildgoose
    Need help identifying a font or something similar to it
    Here is another sort of similar that would be cool to figure out.
  10. Wildgoose
    Do you accept Checks at Shows?
    I don't take personal checks unless its someone I am comfortable giving the graphic to. I don't have checks either (for the business) I use the card mostly and whenever I have cash I use that too, I want to use it up while it's still worth something!
  11. Wildgoose
    Wet is definitely safer. I just did a wet app on a two layer graphic that went on a curved surface and I would not have wanted to chance getting good alignment on the curve. There was also some 7/8" wide pinstripe styling going around this curve and wet was about the only way to get it just right. Wet also has the added benefit of giving the customer a more involved performance so sometimes it may impress them more.
  12. Wildgoose
    nylon reversible bb jersey?
    If it's actually Nylon then you will have to use Easyweed Extra that is specially designed for nylon. If it's polyester then your good with regular Easyweed. Double check because there aren't as many full nylon lines out there as you would think and it's probably polyester.
  13. Wildgoose
    Are there any Mac users out there?
    How is the lag time on the macbooks? I use an imac mostly but have been considering buying an additional macbook pro and was wondering if the processor bogs at all with illustrator? I know even my desktop will slow up sometimes when rendering large tracings or 3D images.
  14. Wildgoose
    Hat creasing..
    I usually pre-press mine and then work the hat further down on the lower platen. Have not ever had an issue with 5 panel hats though. Do you have different widths for your lower? Looks like maybe the platen is a bit too wide for the 5 panel? I have a smaller platen for lower profile hats that I use most of the time.
  15. Wildgoose
    I do one layer at a time and rarely wet. Some do a lot of wet but I find it slows the process down too much. Wham Bam thank you mam. If it's something that is real big and I'm worried about accidental touching then that's when I wet app. Once in a while I will build a stacked project in the shop but like mentioned I find I get more bubbles along the layers. Have not tried a wet install of a stack though and might one of these days just to see if it is any better on bubbles. For me the stack ends up similar to using two pieces of app tape to cover a wider job, always end up with some bubbles at the seam.
  16. Wildgoose
    Mini Tractor Pull
    That must be a new class since I have been around the pulling. I used to go to them a lot. They have a mini class that is not much bigger than those with V8's in them. I had to laugh one year because they had just had the big dogs pulling the big sled and after the last one got done a regular 4x4 John Deere farm tractor came to take it off the track and hooked on and just dragged it off like it was nothing, and it was till setting at the top of the run with the weight all the way up.
  17. Wildgoose
    A whatyamacallit. Pretty cool.
    Cool idea. If it's not $100 I'd probably try it. Did you notice when he was rolling up the green lettering that the edge was wadding up? LOL it didn't look like that was masked yet either but it could have been the light.
  18. Wildgoose
    mx jersey and t-shirt
    I don't use it that often but Thermo-film is pretty cool stuff. Real rubber texture to it, I have found nothing quite like it.
  19. Wildgoose
    Etched Colt pistol
    I would have never thought of that! I'll have to be a little more creative next time I do some blasting I guess. Great idea and thanks for teaching me something new today!
  20. 631 is def tricky and if you have texture (90% of the time) it's even tougher. Being able to get it off means that it isn't as aggressive. I use 651 for a lot of semi-permanent work and 751 for vehicles and higher end signboards like diabond. Have yet to feel the need for the 951. The house brand (GS) app tape performs well. The only complaint I have ever had is that the edges are wrinkly for some reason. Someone on the forum here gave a tip long ago about rolling the app tape out sticky side up and then applying the graphics to it rather than laying the graphic vinyl side up and applying app tape. Real good tip BTW. Well with the Green Star you have to be more careful because something in the trimming process leaves about an 1/8in little crease along the outside edges which occasionally cause issues. Other than that one thing it works great and as long as you are prepared for it to do that then it's not much of a factor. I buy more expensive stuff for full width 24" rolls but always keep a 12" roll of GS around for everyday smaller graphics. The clear stuff from GS is lousy. It will rip when removing which will in turn rip your vinyl. It might not be bad on smaller stuff but I have a 24" roll and hate it. I have been trying to use it up but I won't sell it to customers because they all came back complaining about it so I switched to Clear Choice for my clear preferred.
  21. Wildgoose
    Etched Colt pistol
    Wow I'm totally impressed! Had to be tough to get the grips to look that good. That's my favorite model BTW.
  22. Wildgoose
    retro RC car Hog Heaven
    I don't want it that bad but that gave me a great idea which worked out! Thanks Jbums!
  23. Wildgoose
    I have been trying to no avail to find a better close up of this Hog. It's a long shot but maybe one of you have seen this particular hog. This is about as close up as I have found and it's not close enough for as detailed as it will need to be.
  24. Wildgoose
    GreenStar
    A banner is a great application for GS because it doesn't see 100% use so it gets a break. In my personal opinion I tend to believe softer substrates like that also allow for a little shrinkage to occur without harm.
